REACH M+ and M2
Reach – PPK module
for drone mapping
Deliver centimeter-accurate maps with Reach on a drone. Map wherever you need with less ground control points.
Starting from $265
Choose a receiver
PPK Mapping in the Arctic. Water and Ice
Research Laboratory, Carleton University
Positioning with centimeter accuracy in RTK and PPK
Reach M+
Single-band
Baseline up to 20 km in PPK
$265
Buy
Reach M2
Multi-band
Baseline up to 100 km in PPK
$449
Buy
Precise georeferencing
Save your time and reach remote areas
Reach onboard a drone allows you to drastically cut the number of ground control points (GCPs) this simplifies the setup process on-site and accurately maps even remote areas.
Why camera synchronization
is so important
Usually, the autopilot triggers the camera and records the coordinate it has at that moment. When the drone is flying at 20 m/s and GPS works at 5 Hz, that means your autopilot will only have position readings every 4 m, which is not suitable for precise georeferencing. There is also always a delay between the trigger and the actual moment the photo is taken.
Reach eliminates
the delay
Reach solves the problem of positioning by connecting directly to the camera hot shoe port, which is synced with the shutter. The time and coordinates of each photo are logged with a resolution of less than a microsecond. This method allows GCPs to only be used to check your accuracy.
How to get
started?
Connect Reach to a hot shoe port on a camera
1.
Every time a photo is taken the camera produces a pulse on a flash hot-shoe connector which is synced to a shutter opening.
Fly a drone, Reach will record photo events
2.
Reach captures flash sync pulses with sub-microsecond resolution and stores them in a raw data RINEX log in the internal memory.
Download logs from Reach and base station
3.
After the flight, get the RINEX logs from your airborne Reach module and a base station (Reach RS, CORS or another receiver).
Process logs and get a file with geotags of photos
4.
of photos
Process RINEX files using free RTKLIB software. The file is created with precise coordinates of the photos and can be used for georeferencing.
Compatibility
To ensure smooth synchronization of Reach and a camera, we recommend you use the Reach M+/M2 hot shoe adapter. You can get it in the Emlid store with UAV kit or separately.
Our PPK modules are fully compatible with most cameras with hot shoe including
  • Sony A6000
  • Canon PowerShot A2300
  • Canon EOS 4000D
  • Sony NEX-5
  • Sony Alpha QX1
  • Sony Alpha A7R III
mobile platforms
Comes with
ReachView app
ReachView is easy-to-use software for data collection that is available for both Android and iOS. With ReachView you can control all the features of the Reach receivers, such as setting up a base station, logging RINEX data, configuring NMEA output, and monitoring data.
Camera
control
Reach can trigger cameras as well as register events. The event mark feature is a must for aerial mapping as it allows the precise time when the shutter was activated to be registered.
Simple log
management
Logs are automatically recorded directly to RINEX in the internal memory. View a list of the logs and download them using the ReachView app.
Monitoring
data
ReachView shows current satellite levels, your location on a map, and much more.
Reach is designed for harsh conditions Reach is designed for harsh conditions
Engineered
to be tough
Reach receivers are designed to work in challenging conditions, even in frosty and dusty areas, under the burning sun
-20ºС…
+65ºС
We extensively tested Reach M+/M2 in conditions that simulate coldest winters and hottest summers.
REACH M2 and REACH M+
Choosing between
Reach M+ and
Reach M2
Reach M+
and
Reach RS+
If you work within short baselines, then Reach M+ is an optimal choice.
Reach M2
and
Reach RS2
Provides robust performance and quick initialization, allowing work on long baselines.
RTK
Up to 10 km
Up to 60 km
PPK
Up to 20 km
Up to 100 km
Time to fix
1-2 min
5 sec
Frequency bands
Single-band
Multi-band
RINEX logging update rate
Up to 14 Hz
Up to 20 Hz*
*coming with a software update,
up to 10 Hz now
Reach M+ UAV mapping kit
Reach M+, Reach RS+
and GNSS antenna
$1124
Buy
Reach M2 UAV mapping kit
Reach M2, Reach RS2
and GNSS antenna
$2543
Buy
Reach M+
Reach M+
Single-band Baseline
up to 20 km in PPK
$265
Buy
Reach M2
Reach M2
Multi-band Baseline
up to 100 km in PPK
$449
Buy
User reviews
Luke Wijnberg
CEO of 3DroneMapping
As a brief synopsis of the results, the maximum deviation of points was no more than 0.09m in all axes. This is an incredible result given the fact that the average pixel size of the resulting imagery was 0.045m.
Tuffwing
Drones for Aerial Mapping
Tuffwing performed integration of Emlid Reach RTK to enable precision maps to be made without the use of GCPs. The lateral RMS error achieved is just 4cm according to the Pix4D quality report.
Event 38
Drone Service Company
With Reach, we produced an orthomosaic in the Drone Data Management System™ with 2.45cm horizontal and 5.08cm vertical RMSE, as compared with a survey-grade GPS on the ground.
Specifications
Mechanical
  • Dimensions 56.4 x 45.3 x 14.6 mm
  • Weight 20 g
  • Operating tº -20…+65 ºC
Electrical
  • Input voltage on USB and JST GH 4.75 - 5.5 V
  • Antenna DC bias 3.3 V
  • Avg. consumption @5V 200 mA
Positioning
  • Static horizontal 4 mm + 0.5 ppm
  • Static vertical 8 mm + 1 ppm
  • Kinematic horizontal 7 mm + 1 ppm
  • Kinematic vertical 14 mm + 1 ppm
Connectivity
  • LoRa radio (sold separately)
  • Frequency range 868/915 MHz
  • Distance Up to 8 km
  • Wi-Fi 802.11b/g/n
  • Bluetooth 4.0/2.1 EDR
  • Ports USB, UART, Event
Data
  • Corrections NTRIP, RTCM3
  • Position output NMEA, LLH/XYZ
  • Data logging RINEX with events
    with update rate up to 20 Hz*
    up to 10 Hz now
  • Internal storage 16 GB
  • Signal tracked GPS/QZSS L1C/A, L2C
    GLONASS L1OF, L2OF
    BeiDou B1I, B2I
    Galileo E1-B/C, E5b
  • Number of channels 184
  • Update rates 20 Hz* GPS / 10 Hz GNSS
    up to 10 Hz now
  • IMU 9DOF
Mechanical
  • Weight 20 g
Electrical
Positioning
  • Static horizontal 5 mm + 1 ppm
  • Static vertical 10 mm + 2 ppm
  • Kinematic vertical 14 mm + 2 ppm
Connectivity
  • Wi-Fi 802.11b/g/n
Data
    with update rate up to 14 Hz
  • Internal storage 8 GB
  • Signal tracked GPS/QZSS L1, GLONASS G1,
    BeiDou B1, Galileo E1, SBAS
  • Number of channels 72
  • Update rates 14 Hz / 5 Hz
  • IMU 9DOF
Have a question?
Ask our team
Email us at support@emlid.com or fill in a contact form. We normally reply within one working day. However, in most cases, you will hear from us in a few hours.
This site is protected by reCAPTCHA and the Google Privacy Policy and Terms of Service apply.
